HD 11-E Gauge Panel Question.
bass100
serial no 5175, so this is an earlier model. on the panel I have a temp gauge, volt meter and oil pressure gauge already installed. the upper left corner is a hole - is that where the fuel pressure gauge goes, or is it something else? next, there is a missing smaller gauge (top center)... do you know what it is? last to othe right center is small brass fitting. Do you know what it goes to?
Thanks in advance for tour help.
The upper left corner hole is for fuel gauge and the top center gauge should be dasch light and the right brace fitting is for cold weater engine primer pump and the center hole is for the switch light
