furukawa FL320 A Loader transmission fluid?
DonnyClark49
New User
We have a furukawa FL320 A Loader that I use at work and I can not find anywhere what kind of transmission fluid to use in it. I would greatly appreciate if anyone had this information, or where I could get it. Thank you!
The wheel loader line was bought by Hitachi. Hitachi makes a very high quality hydraulic oil.It's not cheap, but is rated for 4000 change interval. If you don't have a Hitachi dealer close,you can get the oil at a Deere construction dealership, as most of the larger Deere excavators are re-badged Hitachis
(quoted from post at 16:20:22 01/06/15) The wheel loader line was bought by Hitachi. Hitachi makes a very high quality hydraulic oil.It's not cheap, but is rated for 4000 change interval. If you don't have a Hitachi dealer close,you can get the oil at a Deere construction dealership, as most of the larger Deere excavators are re-badged Hitachis
so I have bin putting the same hydraulic fluid in it as my case backhoe for a couple of years and for the last month the trany has bin slipping yester day it wont move at all is my trany tost if so where can I get parts
You should have been using Case TCH fluid in your Case or any good generic equivalent HyTrans fluid,what is the model of your Case,is the shuttle oil level good, about the FL320 the picture is a scan of the Mobil book.
AJ
(quoted from post at 17:34:05 01/06/15) You should have been using Case TCH fluid in your Case or any good generic equivalent HyTrans fluid,what is the model of your Case,is the shuttle oil level good, about the FL320 the picture is a scan of the Mobil book.
AJ
so sorry to sound uneducated on tractors but I'm not a tractor mechanic what you're telling me is that the transmission and the hydraulic fluid are two separate reservoirs I put ATF in the transmission and hydraulic fluid in the hydraulic reservoir if so where can I find the Philip for the automatic transmission fluid
To stop the posts repeating clear the typing area before you start typing,I don't remember off hand where the filler for the Furukawa is,if its the Case you are asking about there are several models with fillers in different places,what is your model.
AJ
(quoted from post at 19:30:39 01/06/15) To stop the posts repeating clear the typing area before you start typing,I don't remember off hand where the filler for the Furukawa is,if its the Case you are asking about there are several models with fillers in different places,what is your model.
AJ
'm pretty much good on my case I know how to service that but furukawa is a whole nother animal I fill up the hydraulic fluid at the top of the motor and was thinking that is what fedthe transmission but I need to look for a place to fill it cuz its lips really bad
