I just purchased a IHC 340 utility tractor that has a Wagner C-110 loader. This unit uses the hydraulic pump on the tractor, not an add on pump that some other small tractors use. It also has a Wagner valve bank to operate the loader. I was asking questions about this loader setup on the Farmall/IHC forum page, but didn't get much help with the loader part of the unit. Now for my questions. Everything I have operated with a loader on it the right had hydraulic lever always controlled the lift cylinders, and the left hand lever controlled the bucket cylinders. On this setup the opposite is true. Is this normal? The other thing with this unit is that there is no float setting for the lift cylinders. I changed the hoses around on the valve bank to, what I thought, was normal operation and there still isn't a float setting. Is this the way these loaders are designed to operate, or is there something wrong with this setup?
