JD 310C Batteries
Tx1850
New User
I've been having problems with the dual batteries, and pulled both to stick on a charger. I however did forget to mark how the cables connected. I'm currently waiting on the manuals to come in, but need to use the tractor later this week. Can anyone tell me or send me a wiring diagram on how the cables are connected?
Thanks
The batteries are connected in parallel just the same way as if you were using jumper cables,go from positive to positive and from negative to negative,if you are having trouble with the batteries going flat it could be that one battery is bad,that will drain the other overnight,if that is happening have them tested.in the parts drawing connect all the red dots together to the positive and all the greens to the negative.
AJ
I'm just curious, are dual batteries primarily for cold weather conditions? I've got a 310C that's only got one battery and only room in the battery case for one. I don't think it ever had dual batteries.
Greg
yep--dual batterys give you much more current draw capability---a heavt duty single battry will do the same thing almost
