Hello Guys, I'm new to the site and have been reading and decided to register In hopes you guys can help me learn about my Dozers. I've started farming and clearing land so I bought a TD15c about a 1981 model and a komatsu D21p-7. My questions are mostly concerning the TD15c.
#1- under the seat is a long dipstick. Is this the transmission stick and what do I put in it?
#2- hydraulic tank is incorporated with the diesel tank, it uses 10W hyd fluid?
#3- where is the filter for the hydraulic fluid?
#4- where is the grease zerk for tightening the tracks?
#5- engine was changed out to a dt466 turbo. There are 2 filters on the right side of the motor, threads facing downward. I assume is the twin oil filters? And it would seem the oil would run out of them facing down. Just puzzles me. Are these for motor oil?...
#6- twin fuel filters on the left side of the motor correct?
#7- I found a pdf spec sheet on my Komatsu D21p on the net that is helpful. Still trying to find one on the TD15c. I'm searching from my phone due to delay of internet installation , maybe I can find some info when that's hooked here at the farm, but some helpful links would be appreciated.
#8- I found out how to check and fill the finals by some threads here. And they use 90-w gear oil?
Anything else I need to know ? And positive advise would be appreciated. Thank you Guys!
