On the off chance you have come across the same type problem one of my drivers is having with his 09 VW Passat,the problem is when parking and manovering into a tight spot there is a hell of a racket coming from the engine,having it checked out the belt tensinor was replaced but the new one it's just as bad if not worse,they now say the harmonic balancer is the reason,I took the belt off and checked all the pulleys for play,the power steering pump feels good,the alternator is free and smooth,the ac is free,the crank pulley looks to be running true,its not easy to grip it but I used a large filter strap and no way is the rubber giving,its nearly 200 from VW,what do you think,the tensioner is jumpimg like crazy when it does it,but its a new OME assembly,what would you go for.
Ed
Ps Its a 1.9 TDI HiLine
Ed
