blueridge
- Location
- Crawfordsville In
We had steering clutches relined to correct thickness per shop manuel and installed them and adjusted with the guage I made per Instructions in manuel. It steers but you have to pull lever back quit bit, i think it's not turning until the brake locks up. Acording to the owners manuel it says it starts to turn when you pull lever and if you want a hard turn you pull lever all the way back to lock the brake. My son and i have both studied this manuel and think it is adjusted correctley. any one have a better idea on this that has had one of these apart. Thanks for your help.
Gene
Gene
