Komatsu D21P6 Steering Troubleshoot - Early 80's
jumps
New User
I have a Komtasu D21p-6 early 80's, ,, i need a littel help figuring out what is wrong with my Dozer.. It runs fine, but it dosen't steer? I pull both levers and it stops, Is there a way to check if i have break probme or clutch problem? Any advice? Anyone in Centerville Texas than can fix it? I will video tape it and an share with you guys for advice. I will pull the floor plate to sho you guys,, anything else i shoud do? My dozer is about 2 hrs away from home,, so it's not easy for me to go back an forward...
By what you say this is a lever steer machine with one brake pedal,each steering lever does two jobs,the first bit you pull the lever disengages the clutch pull it further and it applies the brake,you need to have the adjustment correct,by the sound of it the clutches are ok and disengaging but the brake is not coming on,look up your manual and adjust the clutches and the brakes,it is important that the adjustment is done correctly,you don't want the brake coming on before the clutch is disengaged look underneath the steering clutch housing and see if there is any drain plugs,those brakes and clutches are dry,if oil gets on the brake bands it makes it very difficult to steer,draining the housing gets rid of moisture and sludge.
AJ
(quoted from post at 11:36:20 11/14/14) By what you say this is a lever steer machine with one brake pedal,each steering lever does two jobs,the first bit you pull the lever disengages the clutch pull it further and it applies the brake,you need to have the adjustment correct,by the sound of it the clutches are ok and disengaging but the brake is not coming on,look up your manual and adjust the clutches and the brakes,it is important that the adjustment is done correctly,you don't want the brake coming on before the clutch is disengaged look underneath the steering clutch housing and see if there is any drain plugs,those brakes and clutches are dry,if oil gets on the brake bands it makes it very difficult to steer,draining the housing gets rid of moisture and sludge.
AJ
thanka do you have a. email i can reach you just in case my email is [email protected]
Sorry I don't give out my email or telephone.I'm on the other side of the pond,if you don't have the confidence to do it yourself have a private equipment mechanic do it for you.
AJ
(quoted from post at 16:22:20 11/14/14) Sorry I don't give out my email or telephone.I'm on the other side of the pond,if you don't have the confidence to do it yourself have a private equipment mechanic do it for you.
AJ
Sure i totally understand,, anyhow,, I'll let you know what happen,, I really hope is the break...
Question: Are you puling both levers back at the same time? If so It should stop moving. If you are only pulling one lever back at a time and it stops then the clutch is slipping on the opposite side from the lever being pulled. Steve. www.sadygerts.com
