I've got a 545 Ford with the 3 cyl diesel and a few years ago it developed a coolant leak into the crankcase so I purchased a short block for $2500 plus exchange. Found out later probably from this site that the small hp diesels create cavitation in block where the small air bubbles will eventuality penetrate the cyl wall and cause a leak into the crankcase. The rebuilt block came with only one insert and that was in no 1 cyl. Maybe AJ can enlighten why only one cyl fixed with inserts instead of all 3. So if you're going thru all the trouble of reboring you might consider an insert in the first cyl. Ask AJ for an opinion. Udo
