Case 750D Bulldozer
DozerDave
New User
I have a 750D bulldozer, serial no.7071559. Should this machine have an Engine no. stamped on it anywhere? I am trying to find a head gasket kit for it, and everyone wants an engine no. I cannot find one on it.
Has anyone had any luck sourcing parts for this machine? I think it is around 1967 year, and parts don't seem to be readily available. I found a cylinder head gasket kit advertised at AGKITS, but they will not ship to Australia! I contacted them to see if they could recommend another supplier who might, but they did not even respond to my email.
Highway and Heavy Parts in the US have been really helpful, have the head gasket, but not the other bits and pieces.
If anyone can help with the engine number/model for this machine, or a supplier of parts, I would really appreciate it. I really just need the head gasket kit.
Thanks in advance.
I have found the plate with the engine model on it now - it is an
A267 engine.
I am chasing a head gasket kit for this machine if anyone can help
with that. Main issue is finding someone who will ship to
Australia.
Having a bit of trouble trying to locate a 750D,the parts catalog does not show one,the 750 with a 267 engine has the engine # on a plate directly in front of the injector pump on the timing cover,the valve grinding kit as they call it has a Case part # of A40575 kit,that interchanges to Napa FPG HS8212CS1 kit or just the bare head gasket FPG 8212CS.
AJ
Thanks AJ, it had been painted over twice, and was under a lot of
old grease, but in front of the injector pump is where it was.
I will follow up on the part no's you have described.
I can get the head gaskets here in Australia but they are $130- each,
as opposed to US$26- (about A$30) each in the US. By the time I
source all the other bits and pieces locally, the heads will be worth
more than the whole machine, so if I can find some kind soul who
can sell me some and send them to Australia I will be very grateful.
Thank you Jean Claude - I will keep it in mind.
it is a bugger being on the other side of the world sometimes!
Medium size flat rate box ships International by weight, even a light weight box costs us $50 to ship to AU.
