Hi,
I have an 1990 JCB Sitemaster 4wd with a Syncro Shuttle transmission. The other day I was backing up a small hill when it seemed to drop out of gear. I put it in forward and it works fine. No reverse.
Here is what I have tried so far:
Removed the F/R solenoid valve. When switched from foreward to reverse I can see the valve shaft moving back and forth. I dissasembled the coils from the valve body and reversed them and they still actuate the valve shaft. The coils ohm out the same (~5homs) and both draw the same amperage. I reassembled and still no joy.
Recently (a week before this happened) the hose to the cooler popped off and drained a couple of gallons of fluid. I topped it up and replaced the filter. I have not checked the screen at the bottom of the sump yet.
Any ideas?
A simple question:
What fluid is equivalent to JCB brake fluid?
Thanks,
Chris
Backhoe Info:
mach-s/n: SMBT4010/354682/7
eng: AC532616T
fnt ax: 03633
rr ax: 03400
gearBx 445/164/6/00585
Any ideas?
A simple question:
Thanks,
Chris
Backhoe Info:
eng: AC532616T
fnt ax: 03633
rr ax: 03400
