glennster
posted this in tool talk, they sent me to
you...
ok so i have this old prime mover skidsteer,
vintage 1982. previous owner was running hy-
tran hydraulic fluid in it. i am replacing one
of the drive motors new. trw-ross motor. main
pump is a sunstrand sauer. the owners manual
(finally found one) said to use 10w40 se/sf
rated motor oil. it is an old rating. guy at
the hydraulic shop recommended i run 10w40
motor oil mixed 50/50 with dextron 3
transmission fluid. he said the trans fluid
will add anti foaming and anti wear additives
to the oil. any thoughts???? the main pumps are
axial piston pumps.
you...
axial piston pumps.
