JD straight 450 HLR input shaft
yooper2001
New User
Hello! Thank you for taking the time to read this. My Dads JD straight 450 had the HLR input shaft shear in half. The problem I am having is the Parts Catalog states it is an AT21511, but it is different than shown. On the front of the shaft it has a spline and a snap ring and a keyway on the back of the shaft...but all of the shafts I have found have a keyway on both ends....If anyone has dealt with this before or knows where I can locate a serviceable one help would be appreciated.....Thank you.
Thank you....I also have a thread there...I did find out that the reason why its different is because the dozer has a PTO.....so an input shaft with a PTO....hopefully SOMEONE would be willing to part with one sitting on a shelf somewhere....I would post a picture but do not have the permissions to. Thank you for your time.
