HOW?? VOLTAGE STEPDOWN, 24 TO 12V.?
NIK OWEN
CASE DOZER W/ BAD TORQUE TEMP GAUGE...CAN GET 12 V. FOR $18, VS $171 @@ CASE. GAUGE IS 300 DEGREES, O.K.? SOMEONE ON ACMOC SAID EXPECT ABOUT 250 DEGREES OPR TEMP ON ALLISON TRANS. BE BLESSED, GRATEFUL, PREPARED, NIK
First, find your caps lock key and turn it off.
I would guess (but I could be wrong, it's a guess) that a temp gauge won't draw too much current. If true, a simple 3-terminal voltage regulator in a TO220 package will probably do the job:
Either a 7812 and two capacitors or a 317, two resistors and two capacitors. Depending on actual current needed you may also need a heat sink to bolt the thing to so it does not overheat.
Or you can likely buy the thing in a box (which will likely have something like the above, or a fancier switching converter) for more money if you prefer. Generically, a DC-DC converter (you want a buck [lower voltage] converter, 24VDC in, 12VDC out)
I'm not sure who makes them for Carquest, but take a look at the link below, on page M16, for a resistor that allows you to use 12V gauges on 24 volt systems. I got some years ago, I think through Steward Warner, that looked identical and did the same thing these do. I know of at least one machine that's still in use with them in it after nearly 10 years.
Poke here
If I remember correctly the 1450 had a manual gauge for the torque oil temperature as OME,if you intend changing over to electric you will need a sender unit to put in the torque as well as the gauge,any truck parts outlet should be able to supply a 24V set,what have you got at the moment,any truck salvage yards near you.
AJ
