Anton van der Merwe
New User
Hi there. I own a mf400 dozer. I rebuilt it after I bought it a year ago and only started using it about a month ago for short periods because it was still winter here. spring has come and we average 32-37'C at day time.
The transmission temperature rises to 110'C after 2hours of working. It is a concern to me and that's why I am asking for help. While repairing it I found that the transmission strainer was badly blocked. I cleaned it properly and added new atf transmission fluid and a filter. If the transmission gets that hot the turning of the machine is also difficult.
I do understand that the pumps may have wear on them but will thicker oil do the trick? The oil that came out of it was thicker and brown of color. As the transmission temperature rises it also picks up my engine temperature rapidly because of the oil cooler from the transmission running through the bottom of the radiator tank. I'm sure these machines are made to run longer than 2hours a day?
If anyone can help me with any suggestions please help me.
thanks
thanks
