350c Reverser
russdog
Got back to working on removing the reverser.Got it out without breaking anything. I was wondering where to get the parts to repair it. Also was wondering what to watch out for while disassembling it.I know there is at least one broken gear as there are teeth in the bottom of it. Thanks Ken
You've got to figure out why there's pieces parts like teeth in the bottom of the case.. That's not normal..Unless maybe a bearing failed ?? Hard parts are Deere only.. Clutches and disks can be had aftermarket.. I'll look through my plunder and come up with a list of new old stock parts that I have here .. My e-mail is open..
If you have any questions regarding the repair, give us a call. We offer free technical advice. If you need hard parts we have a few machines we are parting out. We also have the aftermarket parts available as well. Good Luck. Steve. www.sadygerts.com
Thanks Steve. I will be tearing into it shortly. I will know what parts I will need when I get into it. Ken
Looks like I need a spider gear. The teeth are sheared off and I found a thrust washer broke in half in the bottom of the case. What kind of parts do you have? Thanks, Ken
