steven in Tn
there is a 951c here local that i would like to go check out.
pics look nice and clean
from the seller,
1980 caterpillar 951 trackloader. This machine has 2700 original hours. Has water in the oil, which caused either a crank or rod bearing to fail. Will start and run, but has heavy knock. This is a well maintained, one owner machine owned by a power company. Undercarriage is in excellent shape. Trans shifts smooth and brakes work good. This dozer is not junk, engine is only issue
any idea what it would cost to rebuild motor,
probly need new crank or possible turn down, pistons, rings,
bearings, and seals.
i can do most of the work myself.
not sure on the water in oil, head gasket, or head cracked?
asking 6500, whitch i think is too high.
from the seller,
