thomaskd44
[b:5056574fc4]Hello[/b:5056574fc4];
I have been looking to find the best; easiest, most convenient, way to replace the rear main oil seal on my TD 6.
I have read that the only way is to pull the engine. However, there are a few that went into the housing instead. Good information -kinda- without detail. I understand how going into housing works, and will go that way this self. What has not been made clear, no detail; is why the oil pan must come off. Are they saying that you have to pull the pan to remove the lower rear seal housing? I have removed the oil pan, and even removing the rear main, there is no way one may get to the lower housing.
Does anyone have clear, intelligent information in and as to the above??? Also, to do this job I need the torque settings for the fly wheel, drive connection, clutch apparatus, and the rear main seal housing bolts.
[b:5056574fc4]Thanx[/b:5056574fc4] in advance for information; torque settings.
when finished I will give detailed information in and as to repair/replacing the rear main seal.
[b:5056574fc4][/b:5056574fc4]
