1150 case dozer
ben brown
well guy hit a limb with is 1150 case with the 401 broke the exhaust its the three piece manifold of course case don't have them any more and no after market that i can find was wondering id any one might know where one is located or now of a replacement let me know if you would bbrown56athotmail.com thanks ben
ben, there is a gentleman that posts on here occasionally who is an artist with cast iron manifold repair. His handle is "georgemd". If all else fails, you might search past posts for his contact information and see if he may be able to help.
well as you would expect never could come up with exhaust manifold for the old 1150 so ordered one for 930 1030 case tractor with 401 engine 2 piece one with new gaskets thing bolted up good only thing is i had to cut a hole closer to the front for the exhaust and use a different muffler witch i have one for a early model 4020 and i do believe it be slight bit less hard on the hearing so it be going on thanks to all those who helped
