reasonable repin and rebush HD3 ?
Forum Members,
I am considering replacing the worn pins and bushings on a '65 HD3 Allis. Had checked with Ziegler and their cost was prohibitive. Found another shop that will do it for $1800.00 if they can get correct pins and bushings. Is that in the park?? Any and all thoughts are welcome!
Mr. T. Minnesota
Sounds high but i may be out to lunch. There were two different size p&b I have a couple sets but I'm saving them for some use tracks i will do this winter if still alive. I will double check my stock and check my used chains to see if i need them all
Sounds ridicules to me. IF they are still out there new rails should not cost more than however I know some ac stuff is hard to find. Check around on the web you should easily beat that price.
