broken bolts on jd 450
Hello I have a jd 450 straight dozer. while doing some maintenance on it I noticed two bolts missing/broken both on same side of what I believe is the bell housing. I can see them easy enough thru holes in the frame. The 2 on the other side are fine. I believe these have been this way for a while. Short of splitting the machine in 2 is there a way of removing them and replacing.There is not a lot of room around them.
Any help would be appreciated.
MC
Ah yes, One of my favorite jobs.... NOT... You will have to get very creative on some of these bolts.. I have a air angle drill , which allows me to get to different angles to start a center hole.. I use a wooden dowel with a drill hole in the center of it to guide the drill to the center of the broken bolt.. Start with a 1/4" drill [ very sharp ].. drill in about 5/8-3/4" with the 1/4" drill bit.. Then enlarge it to 1/2".. This should allow you to drive in an easy out to remove the broken piece.. Hopefully , the broken piece is still there and not just missing.. Usually the missing ones have buggered up threads.. If the side ones are missing/broken , then the bottom ones are usually the same.. Happy drilling.. Removing the top roller bracket from the track frame sometimes gives some more clearance with a cable come-a-long to lift the track up.. That is if those bolts will come out..
neighbor had the same trouble with his 450. He drilled out the holes & put 1 inch Catapiller bolts in it.
Thanks for the advice. It appears it is just the top 2 side by side bolts. Roy, funny you mention the wood dowel I was thinking cutting a 3/4" hole saw plug it is about 5/8 on the inside and the mandrill makes a centre hole at the same time. "If only dozers were made with wood"
Good tip on the roller, I am going to try a flex bit on the drill and maybe add a angle air drill to my tool box. Do you think heat will help ?
tell me if I am crazy, here was my plan!
drill 1/8 hole thru bolts then 1/4" assuming bolts are not bottomed out spray in break away.
keep increasing drill size until I get real close to the threads then try a bolt extractor/heat?.
u cannot see in the hole so to get a straight in peek I gotta use a mirror ! All fun !!!
I'm a fool for Good , Expensive , long lasting air tools.. I've got a Snap-on 90 degree 3/8 air drill that I've used extensively for broken bolts.. Wouldn't be without it.. You can try heat but, it is hard on easy outs.. Ruins their temper..
