Reverser clutch fluid?
Forum Members,
Would like to replace fluid in reverser clutch reservoir on the '65 HD3. What kind of fluid is required for this clutch? Any and all thoughts are welcome.
Mr. T. Minnesota
The Shell book says that the reverser,torque tube,shuttle and diff takes Spirax S4 TXM,the final drives takes Spirax HD 80W-90 gear oil,the hydraulics Formula Shell SAE 10W-30 motor oil,the engine Rotella T3 15w-40,coolant Rotella ELC Pre-diluted 50/50,the amounts are not listed.
AJ
AJ,
Any idea of how much fluid is needed? HD3 is in northern Minnesota and wish to pick up the fluid in central Minnesota. That is 3.5 hours away. Any and all help is appreciated.
Mr. T. Minnesota
Shell did not list the refill capacity, I nosed around and found the following information,how accurate I can't say,the refills are in litres, Shuttle 7.9 to 9.9Lts, Final drives 6.25Lts each side,Hydraulic reservoir 11.3Lts and the engine 4.7,it does not say with or without filter changes.
AJ
