Case 580k horn and flashers and RTD
thartiga
Recently acquired 1992 Case 580K. A couple of things don"t work trying to figure out.
1. The horn doesn"t work. Has power and the relay is kicking in (can hear it), but cannot find where the actual horn is. Anyone know where this is located?
2. Flashers and turn signals don"t work. The lights work (checked), getting power to and from the switches. Suspect the relay, but there are 2 relays in the compartment. One has been messed with and suspect possible misswired. The diagrams don"t help much. Prior to spending $70 on a new one, anyone have a pic to verify?
3. Return to dig. How does this work exactly? The manual is vague. Is this a switch that is activated when moving the lever to the up and left?
Thanks.
Tim
return to dig is nothing very technical. you have to do it all yourself with the loader joystick. is basically saying if the self leveling bucket is functioning properly (most that age don't) you can jam it all the way to the left and the self leveler will stop the bucket at level and you can also jam it all the way forward to float and it will stop at ground level although I wouldn't recommend this method cause the bucket hits the ground pretty hard its better to control it too the ground manually. i'm not sure on the k's but most of the horns are up around or in front of the radiator. might even be attached to the grill on the hood. they have a tendency to go bad. look at the back of the grill when you open the hood. as far as the flashers I have no idea
I'm thinking the horn is under the floorboard , mounted to the frame .....It may be broken off , look for a dangling wire .
