The electric fuel shutoff solenoid on my 1150E burned out this spring,we have been running it manually since. The new one I have came from Case and is just the same as the old one. When I put it on it won't work, if you push the plunger in it will hold it until you cut the power. But it will not pull the plunger in like it should. It has three wires going into it, one is ground, one has 24 volts to it with the switch on, the other don't seem to do anything. I wouldn't think the new solenoid is bad, but something isn't working like it should. If anybody has any ideas I would like to hear them.
