Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: komatsu d41 vs cat 941b
AJ.
08-10-2014 13:18:55
The Komatsu's that I came across were been used by large contractors in the demolition business,I have not see any D41S finals fail or transmissions failure,the plus side of the Komatsu over the Cat is the segment sprockets,wider pads and stronger track frames,when the undercarriage has to be changed its just split the track,change the segments/rollers and idlers,reseal the adjusters,drive from the old track to the new and connect it up,Cat,split the track,remove the track frame,remove the sprocket hub,pull the sprocket,take the cover off the final to inspect it,cover on ,press on the new sprocket,drill out the bolts that broke in the frame when it was removed,put the frame back on,new adjuster seals then the track,so you can see why the Komatsu was poplar,with any machine it is the amount of work done and the way it was used and looked after.
AJ
steven in tn
08-10-2014 15:16:15
 Re: komatsu d41 vs cat 941b in reply to AJ., 08-10-2014 13:18:55
anyone know what year?
d41s-3
ser 06426
thanks for everyons help.
Copyright © 1997-2015 Yesterday's Tractor Co.
