Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JCBexcavator
AJ.
08-10-2014 08:40:54
Unless the spindles are leaking in the top cover leave it be as the governor springs are connect underneath the cover and needs delicate handling and putting back in the right places,when you open any part of the CAV system it is a right SOB to get the air out,you bleed it up to the two bleeders on the pump finishing with the highest one,keep operating the feed pump till the lever goes limp,with the stop in run position,the throttle on full loosen all the injector pipes a couple of turns each at the side of the injectors,not the top,with a good battery crank the engine over till fuel starts to spurt from the pipe unions,tighten them up and hopefully it will start.
AJ
Copyright © 1997-2015 Yesterday's Tractor Co.
