TractorLinks.com
Re: 1985 Liebherr 924 Excavator Losing power
AJ.
08-09-2014 18:18:48
The filters are in the hydraulic tank,look on top of the tank you will see a round plate with a circle of bolts the suction filter is under that,in the same area there is a smaller round plate with two slotted lugs,under that is the hydraulic filter with a magnetic rod,you need to look at that, there will be a little metal residue but that's not a worry,but if you have metal filings it best to not run the engine till the cause is sorted, have look at the tank outlet on the outside,the tank has an on/off valve,the lever must be looking the direction of the pipe to the pump,check that,also check that the arm rests go down properly and any safety lever is functioning properly,has that machine the option for to change the lever functions,if it has see that it is in the proper position,what happened at the start of this trouble.
AJ
