TractorLinks.com
Re: Update on jd350c knock
roy suomi
08-07-2014 08:34:32
If the knock is there only on start-up and shut-down , That's the straight cut gears on the countershaft meshing with the clutchpack gears.. Not a problem.. Many do that on start-up and shut-down.. If it's something that has just started to do, I've seen the countershaft bearing end break off the shaft.. Not a bad job, Just look it over and take it apart as needed.. To overhaul , set the reverser upright on it's tail and start from the front [ after you drain the case ] .. You might need a helping hand when the clutches come out as the countershaft comes out with it at the same time.. You must remove the control valve to release hollow locating pin that secures the clutchpacks in place..
