Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 1985 Liebherr 924 Excavator Losing power
AJ.
08-07-2014 08:02:51
I doubt very much if the hydraulic pump has failed,if it has and you kept using it the whole system will be contaminated with metal fragments,valves cylinders and motors,if you suspect the pump pull the main hydraulic filter and the suction filter,examine them,if there is no lumps of metal in them put them back, have a good look at the switches on the dash,that machine if its a Litronic has several modes,if for example if its in heavy lift the flow from one section of the pump is dumped,the machine slows up etc to make more use of engine power,extra pressure is put on the main regulator valve and the machine will lift more(I take the engine is running properly)see what lights are on the dash,check to see none of the multiplugs are out or fuses blown,the next thing that could be wrong is the main regulator valve is stuck open or has blow an o'ring on the body,check them couple of things and see how you make out.
AJ
