TractorLinks.com
1952 TD 6 IH dozer, crawler Rear main oil seal leaks, how do
thomaskd44
07-30-2014 18:14:31
Have a TD 6 The rear main oil seal leaks; like a stream.
I have learned that the best way is to pull the engine -don't agree. Another way to take top plate off, move clutch/fly wheel back and remove seal; also remove spring to remove oil pan.
Which is the best way and how? I again don't think pulling the engine could be the best way.
Thomas
AJ.
08-05-2014 12:51:24
 Re: 1952 TD 6 IH dozer in reply to thomaskd44, 07-30-2014 18:14:31
The drawing is from an old parts book for a TD6,trouble is I don't know what TD6 it came with, could be later than 52, it shows the seal layout,I put the part numbers that are listed of the two pieces of felt and the gaskets,if you can't find them locally try the link below.
AJ
http://www.olsonsgaskets.com/
thomaskd44
08-08-2014 12:05:47
 Re: 1952 TD 6 IH dozer in reply to AJ., 08-05-2014 12:51:24
Thanx A J I remain delighted with your response, and more importantly your desire to help -mankind; whatever that is.
Mucho Gracias
Muito Gracias
Dunka
Hell, thanx
thomaskd44
08-08-2014 12:05:03
Mucho Gracias
Muito Gracias
Dunka
Hell, thanx
jm.
07-31-2014 18:43:14
 Re: 1952 TD 6 IH dozer, crawler Rear main oil seal leaks, how do in reply to thomaskd44, 07-30-2014 18:14:31
I will tell you waste of time to consider anything but removing the hard nose and engine.
thomaskd44
08-03-2014 09:49:54
 Re: 1952 TD 6 IH dozer, crawler Rear main oil seal leaks, ho in reply to jm., 07-31-2014 18:43:14
Quoting Removed, click Modern View to see Why do you say this?
