Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Removing brakes HD 6
gemdozer
07-30-2014 02:57:28
After removing the support bolt under housing you should be able to play with the brake band to get inlingne the pine with the hole and you do need loosen the anchor block
ejensen
07-30-2014 05:50:11
 Re: Removing brakes HD 6 in reply to gemdozer, 07-30-2014 02:57:28
Gemdozer,
I was able to take a picture of our HD6 off our website. Thanks ,
Chris
Left fender and battery box shown in picture. I think access to the holes in the frame to remove the brake pins would be better if the left hand fender battery box were removed. What do you think?
ejensen
07-30-2014 05:29:33
Gemdozer,
Thanks again for sharing your expertise on HD 6 crawlers. Looks like access to the holes in the frame would be better if the left hand fender were removed. What is your opinion regarding removing the fender?
A good view of the left hand side of our HD6 is available on our website:
einarjensen.com
I was able to get new brakes from General Gear in Idaho. Also bought a new yoke for the top brake band. One on mine is good but I didn't know it was okey until I removed the brake cover.
Thanks again,
Chris
gemdozer
07-30-2014 10:20:55
 Re: Removing brakes HD 6 in reply to ejensen, 07-30-2014 05:29:33
You remove the fuel tank but not the finder for removed the brake band and pines
ejensen
07-30-2014 17:21:51
 Re: Removing brakes HD 6 in reply to gemdozer, 07-30-2014 10:20:55
Gemdozer,
Thank you for the information about the fender. A lot less work to leave the fender in place. I will loosen the block which retains the brakes.
ejensen
07-31-2014 05:34:53
 Re: Removing brakes HD 6 in reply to ejensen, 07-30-2014 17:21:51
Gemdozer, Thanks for the information. Good news to me as I was thinking it might be difficult to hold the bolts on the block if the nuts were loosened on the outside.
I forgot to remove the bottom bolt which adjusts clearance for the brake band to the drum. I have my place on Orcas island in the San Juan islands. What part of the country do you live?
gemdozer
07-31-2014 04:13:37
You do't need to loosen the block you just play whit the band and pine band should be easy to pull out and should be more easy to enline the second pine
ejensen
07-31-2014 05:30:43
 Re: Removing brakes HD 6 in reply to gemdozer, 07-31-2014 04:13:37
Gemdozer,
That is great news to me. I was thinking it could be difficult to hold the block bolts on the inside of the housing if the nuts were loosened on the ouside of the housing. One thing I realized is that I forgot to remove the bottom housing bolt on the clutch housing which sets clearance for the bottom of the brake band to the drum
I don't know if you are familiar with Orcas Island in the San Juans. My HD 6 is located on a piece of property we have which is 15 miles from where I have my small shop and tools. I prefer to avoid what I call field repairs and like to have eq. at my small shop where I keep my tools. I was thinking about having it hauled to my shop. Very expensive here as the only person who does this type of work has a very large multi axle tilt trailer and a 10 wheel truck for pulling power. He hauls a lot of very large excavators. Much bigger equipment that needed to haul my HD 6 but only choice I have. Your experience is greatly appreciated. What part of the country are you located. Chris
gemdozer
07-31-2014 08:58:51
 Re: Removing brakes HD 6 in reply to ejensen, 07-31-2014 05:30:43
I am located STE-JULIE near MONTREAL CANADA and yes with the bolt support removed you should be able to play with band brake for inligne the hole and some time the pines are worn and have a grove on
Copyright © 1997-2015 Yesterday's Tractor Co.
