TractorLinks.com
case 750 brakes
case750
07-29-2014 20:25:32
I just purchased a case 750 crawler. Everything on it seems to work except the brakes as the pedals just fall to the floor when pushed. Im a newbie to crawlers so does anyone have any advice?
AJ.
07-30-2014 00:31:01
 Re: case 750 brakes in reply to case750, 07-29-2014 20:25:32
The brakes are hydraulically operated,there is a master cylinder for each side,there is a disc brake for each side,each has a slave cylinder,if the master cylinders are empty or there is air in the system the brakes need bleeding.there is a bleed valve on each slave cylinder,use the same fluid as the transmission or hydraulics Case TCH.
AJ
