TractorLinks.com
Re: JD 450C Hydraulics bit the dust
DGH
07-24-2014 19:36:41
The backhoe's were usually put on loaders and where designed for the loader hydraulic system.
The loader used a 28 gpm pump with a 2250 psi operating pressure. The dozer used a 15 gpm pump and a 1750 psi operating pressure.
28 gpm is too much for the dozer. It would be too fast which would make fine grading very difficult.
Too make things work on a dozer with the 28gpm pump you need to use a selector valve so you feed one or the other but not both at the same time. When you select the dozer you need a flow regulating valve to reduce the flow to the dozer and bypass the rest to the tank. The issue here is the bypass flow must go through a small opening to reduce the pressure this heats the oil. Not good but you can live with it.
Too set this up you need some one that knows hydraulics!
jdemaris
07-25-2014 05:38:41
 Re: JD 450C Hydraulics bit the dust in reply to DGH, 07-24-2014 19:36:41
We sold many 1010s, 350s, and 450s with the so-called "23 GPM" pumps and dozer setups. It was an option if the machine was going to have extra hydraulic attachments like a rear ripper, remotes, etc. The big pumps worked fine with the dozers. Only issue was blowing off the return hydraulic filters when revved up with cold oil. But that happens with the smaller pumps also. "GPM" for a pump has no meaning unless expressed at a given RPM. Deere used 1.3 cubic-inch-per-rev pumps as standard on many dozers and 2.3 cubic-inch-per-rev pumps as optional pumps on dozers and standard on loaders. Also some bigger pumps up to 2.6 cubic inches.
A 1.3 cubic-inch Cessna flows 17.9 GPM @ 2500 RPM and 9.7 GPM @ 1800 RPM.
A 2.3 cubic-inch Cessna flows 25.5 GPM @ 2500 RPM and 16.3 GPM @ 1800 RPM.
A 2.6 cubic-inch Cessna flows 26 GPM @ 2500 RPM and 18.3 GPM @ 1800 RPM.
A 2.85 cubic-inch Cessna flows 28 GPM @ 2500 RPM and 20 GPM @ 1800 RPM.
DGH
07-25-2014 09:53:31
 Re: JD 450C Hydraulics bit the dust in reply to jdemaris, 07-25-2014 05:38:41
I think we talking 450C here, and that machine has a rated speed of 2500. The 23 gpm pump was an option for the dozer, usually used when the 9550 hoe was installed. But there were not that many of them make. The most common was the loader with the 9300 hoe. So when looking for a used hoe the most likely one he would find would be the 9300.
