Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: installing brakes on HD 6 crawler HD6E 6714
gemdozer
07-21-2014 14:17:39
Yes you need to removed the fuel tank and loosen the support brake band bolt under the stering cluch housing
ejensen
07-21-2014 14:58:32
 Re: installing brakes on HD 6 crawler HD6E 6714 in reply to gemdozer, 07-21-2014 14:17:39
gemdozer, Thanks again for the information. I have forks on the bucket of my tractor. It fits nicely under the tank which makes it easy to remove and reinstall the tank. Yes, the band tightening bolt underneath. I will definitely remove it. Chris
You obviously have knowledge about the HD6. Do you have one?
gemdozer
07-22-2014 02:13:55
 Re: installing brakes on HD 6 crawler HD6E 6714 in reply to ejensen, 07-21-2014 14:58:32
I had one on my land but it was 15 years a go but I dismantled 5 HD6 for parts and am still have some used parts
ejensen
07-29-2014 05:51:06
 Re: installing brakes on HD 6 crawler HD6E 6714 in reply to gemdozer, 07-22-2014 02:13:55
gemdozer,
I have new brakes and yoke for the left hand brake on my HD6. What holds the pins in place that secure the brakes? There are two holes in the frame which look as if they should line up with the pins. They do not line up. Maintenance book on the crawler I have says the pins are drilled and tapped. insert bolt, I do not know the correct size of the bolt, insert bolts through holes in frame and put into pins and remove the pins. Are the pins a press fit? Is it necessary to loosen the retaining block which both brakes attach in order to line up the pins? Manual I have is the service and maintenance manual for the crawler not a shop manual. I replaced the steering clutches both sides of the machine about 10 - 15 years ago. Right clutch works perfectly, no signs of oil on left hand steering clutch. I think I released the steering clutches pulled them up far enough up and removed the small pin which attaches the two brake bands together. Any information procedures you could suggest to me would be appreciated.
Copyright © 1997-2015 Yesterday's Tractor Co.
