Anonymous-0
It turns out I do need to take the starter out of
my Cat 931B. Tried a bunch of things and then took
the end cap off the starter motor. No oil but a
big rust spot on the bottom, so I'm thinking water
must have slowly got in from melting snow or
something?
I managed to get the top starter bolt loose with a
stubby wrench and a pry bar on the frame for
leverage. This weekend I'll pull the belly pan to
hopefully get at the other 2 bolts. I think it
will have to come out the bottom but there's an
oil cooler line there. Maybe I can push it out of
the way, won't know till I see it. I read of
someone else taking the starter out the top but I
think even if I remove the hyd. hoses on the pump,
my pump is too big to get the starter out? Does
someone know if the optional piston pump to run
the backhoe is longer/bigger than the standard
pump? Any help you could provide to get this darn
thing out would be greatly appreciated. Then
getting it back is going to be a job in itself.
something?
