Anonymous-0
When it rains, it pours!!! I had the battery checked in my 931B and it was putting out 1200 cranking amps, so I ruled it out as the problem. In the past when I thought the battery was low, I was always able to boost it. I cleaned the battery connections and am getting 12.58 volts at the starter solenoid, the same as the battery volts. I get a light click and sometimes I get a louder click but never got the engine to turn over. It has a Nippon Denso starter that I had checked out when the engine was out a few years ago.
There is a small solenoid that feeds to a larger solenoid. The small solenoid is what makes the lighter click sound. If I put a jumper wire from the small to the large solenoid, it does the same thing as turning the key. The only light I have is a little light for the dash. It dims when I get the click. I'm wondering if maybe the large solenoid is stuck or has carbon deposits on the contacts like my skid steer with a ND starter had? I've also read bad battery cables could show good voltage but fail with a starting load? Is there a way to take the solenoid off without removing the starter or could it be something else? Attempting to remove the starter would be the worst nightmare in the history of man. I can probably lift the boom up with skid steer to have a little better access because it's hard to see with the lift cylinder in the way. Any help is greatly appreciated.
