Hi
Rolled a track off, worked at trying to get it back on - finals drives were still working, came back a few days later- got track in position to roll it back on- started it up and have no drive.
Drive shaft is turning both in high and low, wont work in forward or reverse -
one brake will work if you pump it - have tapped around trans contol valve.
Neither gauge shows any pressure.
Trans fluid is 1/4" from full mark.
Sitting with rear a bit down hill.
No visible leaks.
Two lines running from trans control to very back of dozer - one was a bit loose.
Any Ideas?
Were should I check for suction leaks?
No visible leaks.
Any Ideas?
