1960 TD-92 Positive Ground Question
My TD-92 has 2 6 volt batteries hooked up together in series. It is a Positive Ground Application.
Now every time I want to start it. A jump from the booster pack is required. So I know I need new batteries.
Can I buy one 12 volt battery and hook it up positive ground??
I would install a group 31 battery in it. Are you sure it is positive gound? Most 12 volt systems used in IH tractors use negative ground.
