Tractorman007
New User
My 3500A diesel backhoe cranks about 5 revolutions then the starter motor stops turning like the batteries are too weak or there is a load from the engine/trans on it. It will only turn over 1-2 times on 2nd turn of the key. The two six volt batteries are new and fully charged. Cranking is unaffected by jumping. All cables are cleaned and tight. Added a 2nd ground and replaced the positive to starter cable. Starter is new...both starters do the same thing. Thinking that the clutch pedal is not unloading the hydraulics...it is a synchromesh transmission, not a hydro. Tractor runs well except for this cranking issue. Anyone have any experience and suggestions?
