JustinCase125
New User
I just purchased a case 310G serial puts it at a 68 with the 188 diesel. I have gone from bow to stern replacing worn parts and making adjustments to make it like new for season. It seems to me that the hydraulic system heats up rather rapidly <20 minutes run time to about 140 deg F with minimal to no system operation. It has a D41390 pump from what I can tell, and a VDP 22 control valve for the 6 way with a wet line installed for a removable backhoe that the owner before the owner installed. I was told that he had to have the pump rebuilt because he toasted it and he was told he didnt loop the wet line when not using the backhoe and thats what did it. He has a little 1/2 hose loop that is installed via quick connect to the right of the control valve looping pressure and return to what would go to the backhoe when attached to the tractor. Does anyone have any suggestions, specifications for operating or relief pressures, acceptable pressures and specific locations, etc. It has a pressure gauge installed on the "discharge" of the VDP 22 to the wet line that maintains 400 PSI through the loop-which I would assume is the backpressure of that short circuit, also, there is a small 1/4 hose that goes from a street t at that same area up to the far left top of the VDP 22 (which looks like the top of the relief valve) HELP! I understand 140 isnt too hot for a system without a cooler, however, I havent gotten this machine really working yet as its not at my property and that seems hot for not doing any real work.
Thanks
Thanks
