Allis H4 crawler parts numbers
pinball
Finally got the H4 Allis crawler in the barn. After quick inspection I know I need a top roller as the one on the left side is egg shaped. Sprockets probably but maybe just one. I was told its a 1967 by owner. I haven"t been able to find serial number yet. The roller where it fastens on is next to the body. Can some one give me the parts numbers for the rollers and sprockets. Are the rollers/sprockets the same numbers on the h3, 650,653/655. Thanks for reading
SHOULD BE THE SAME UNDERCARRIAGES ON YOUR LISTING. WHERE ARE YOU LOCATED, SOMEONE MAY BE CLOSE ENOUGH TO STOP BY AND HELP YOU. PARTS CAN BE OBTAINED FROM BLOUNT IN GEORGIA. 1-800-659-3111.
No - the rollers change. New rollers now sold for the 653 will fit the H3,HD3,H4,and HD4 but it requires modifying or removing the bottom rock-guards. Bottom roller #s for the HD4 won't help you since they sub over to the new 653 type rollers.
1960s HD4 part #s
Front idler wheel - 0252161-5
Bottom roller - 244430
Upper roller - 233950
Sprocket (full) - 0250151-6
Sprocket (skeleton) - 0250152-8
You should buy my HD4 for a parts machine. Newly rebuilt engine with used original dozer tracks, sprockets, and bottom rollers all in excellent shape. Top rollers are NG though.
