310 case crawler removing gas tank
pinball
I have a 310G Case crawler. The fuel line is plugged. I am attemting to remove the gas tank. It looks as thought the rear weight has to come off to get the seat brackets off. Can someone tell me the best way to get it off. I have all the bolts loose. It looks as though I have to pull it straight off. al help appreciated. norm
First off I am not too familiar with your machine so forgive my ignorance but is it necessary to remove the entire tank? Can the line be removed from the bottom of the tank and the tank cleaned from the top or is the filler opening too small to get the gunk out? I removed lines on a gas tractor some years back and blew 'em out with an air hose when disconnected at both ends. The tanks I cleaned with a shop vac and a long nozzle (After I emptied it of course lol). I am sure I am not of much use to ya, just want to help. good luck bud!
