Starter will not turn. Thought solenoid went out so replaced it.
This is the kind with the key with 2 sharp points that goes in ign switch and a knob right above it to turn to engage that starter. Have 25V at starter switch until ign switch is turned on and then 0 volts to starter switch. Does anyone know where the fuses are on this thing? All was fine and I just got on it one day and it wouldn't start. My cousin put the starter Solenoid on and I wasn't there so I don't really know if he has it wired right
Any help will be appreciated
Assuming the solenoid is wired correctly,I would look at your battery cable connections, and ground connections. Sounds like a bad/dirty connection
You probably just blew the circuit breaker somehow. It should be located on the dash or around the batteries. It's just a round button, usually red or blue with numbers stamped into it(like 30 or 60, which is the amperage rating of the breaker). If you can push it and it makes a snap sound, then it was tripped and you have now reset it.
Let us know how it turns out.
