Any clues as to why the turn signals/4-ways don't work? I replaced three blown bulbs and the 3 prong flasher unit. There is power at the fuse block and the flasher mount has power and ground.
I installed a 2 prong moto flash, pulled the dash switch and had current on the hot terminal and one other before replacing the three bulbs. The right front lamp flashed but doesn't when I replaced the flasher with the 3 prong unit.
Could the switch be bad?
