Hi all, I have 955 k serial 85J',,,,, last year I had the joints between engine and trans go. I found the part ( four rubber pucks)and replaced them how ever after about 20 minutes of idling I felt a vibration. When I crawled under three of the four new joints were torn apart.
Now I am wondering when I put it together I might half been half hole out. As I was replacing them I start the back to bolts and tightened them how ever I could only get one bolt on the trans side so I back all bolts off and I was able to get them started . There no oil leak from transmission side and the flange has some play but not that bad maybe just a little more than engine side.
If any one has any idea what I have done wrong or is there more wrong with the machine .
Thank you in advance for any help
Herb
Herb
