mnoliverguy
I have tested pressure and have 180-190 even after a couble hrs running, Pushes good in low good in reverse and sometimes in high but does not seem to come back to pressure all the time in high range. I have adjusted the clutch and checked the pressure valve for shims all seems to be in order. It shifts a little hard into reverse but not into forward. low maintains pressure well but hard to keep high moving, it has new filter in front by cooler and I have flushed the trans with diesel fuel. When I put in the clutch the pressure starts to drop. Is this normal for this machine? Any help would be great. THANKS
