Mike Burgin
New User
All test done cold:
Pump pressure – 360lbs
Speed Clutch pressure – 100lbs
Direction Clutch Primary pressure – 0lbs
Direction Clutch pressure – 0lbs
Transmission Lub Oil pressure - .5lbs
Outlet From Torque Converter pressure - 56lbs
Sequence Relief Valve pressure – 350lbs
Inlet Torque Converter pressure – 360lbs
Steering Clutch Piston pressure – Right- 240lbs, Left- 270lbs
We replaced seals in torque converter outlet.
Replaced deals in torque converter inlet.
Cleaned filters.
Replaced seals in steering clutch.
Fixed spring leak in corner on transmission with a new seal.
NOTE: On the torque converter and sequence relief valve there was no oil, but after cleaning, oil is now passing through these parts. The loader did move a little before we cleaned things up, now it will not move at all.
Cleaned filters.
