TD 6 will not swap over to diesel
Ralphard
New User
I have a TD6 that will start good on gas but when try to swap to diesel it's just lke you turn key off.Try to do it slow act like it get a little diesel then zap kills gas then nothing.motor stops juswt like you turned the key off.
Search "TD-6 fuel" on this site-many good discussions that pretty well cover the various causes of this problem. Also a good learning exercise.
is the fuel system bleed? like was it running on diesel prior , or is this something you are just getting running? do you have experience with these engines or first timer? give more info.
thanks after 2 days working on it bleed the second filter while running on gas and got it running on diesel
