Hi all,
My trusty but old HD4 crawler sort of bit the dust today. It has been a reliable performer mostly, except for the need to replace almost every hose on the machine. But today it started pumping transmission fluid on the ground and I shut it down immediately. I found the problem (I think). One the left side of the tractor was an open hole in the transmission casing about where the torque convertor would be. When running it was splashing trans fluid out the hole which is about 1-3/8 in diameter. I expect that AC had put a sheet metal plug in the hole and for some reason it blew out. Anyway, I bought a rubber expandable plug at the auto parts store and installed it. Seems to have done the job.
So then with the obvious leak sealed I added three quarts of trans fluid and the tractor worked okay for about a minute or so. So I added another three quarts and then later another 2 quarts. And now it moves around pretty well but lacks power in the drive train. It stalls pretty easily when pushing a pile of dirt which it had no problem with before.
So is my trans toast? Maybe a clogged filter or a stuck relief valve somewhere? I shut the machine down just as soon as I found the transmission oil leak so don't think it was damaged. But who knows?
Any and all opinions will be appreciated.
Randy
Randy
