Winch is on a 310C case, it doesn"t engage.
The drum wobbles 1/4 inch, I pulled both end caps off and
both outer bearings are fine, thru the fill plug the ring gear
is turning and looks fine. When you pull the handle to
engage the drum/spool it feels like the teeth inside are
rounded or out of alignment. Does anyone have a manual
or pictures of this model apart, or a parts blowup, or where
to get a manual?
to get a manual?
